I am trying to disable the LED on a GE zwave plus outlet using the services control panel, but the changes don’t seem to be taking effect. I am running the HASS.io, so I don’t have the ozwcp available.
Am I missing something obvious, or is there a better way to do this?
https://products.z-wavealliance.org/products/2236/configs
OZWlog.txt
2017-12-15 08:48:41.465 Info, Node018, Configuration::Set - Parameter=3, Value=2 Size=2
2017-12-15 08:48:41.466 Detail, Node018, Queuing (Send) ConfigurationCmd_Set (Node=18): 0x01, 0x0d, 0x00, 0x13, 0x12, 0x06, 0x70, 0x04, 0x03, 0x02, 0x00, 0x02, 0x25, 0xb9, 0x1e
2017-12-15 08:48:41.468 Detail,
2017-12-15 08:48:41.468 Info, Node018, Sending (Send) message (Callback ID=0xb9, Expected Reply=0x13) - ConfigurationCmd_Set (Node=18): 0x01, 0x0d, 0x00, 0x13, 0x12, 0x06, 0x70, 0x04, 0x03, 0x02, 0x00, 0x02, 0x25, 0xb9, 0x1e
2017-12-15 08:48:41.478 Detail, Node018, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-15 08:48:41.481 Detail, Node018, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-15 08:48:41.598 Detail, Node018, Received: 0x01, 0x07, 0x00, 0x13, 0xb9, 0x00, 0x00, 0x0c, 0x5e
2017-12-15 08:48:41.598 Detail, Node018, ZW_SEND_DATA Request with callback ID 0xb9 received (expected 0xb9)
2017-12-15 08:48:41.598 Info, Node018, Request RTT 129 Average Request RTT 143
2017-12-15 08:48:41.599 Detail, Expected callbackId was received
2017-12-15 08:48:41.599 Detail, Expected reply was received
2017-12-15 08:48:41.599 Detail, Message transaction complete
2017-12-15 08:48:41.599 Detail, Node018, Removing current message
