Trying to extract the state of my lock to a binary sensor
I got this set up:
    sensors:
      lock_frontdoor:
        friendly_name: "Hoveddør lås"
        device_class: lock
        value_template: "{{ states('lock.poly_control_danalock_v3_btze_locked') }}"
if I put
in the template check in developer tools, it shows the state correctly, but not in the binary sensor?
I want it in a binary sensor, as I don’t want it to be able to lock/unlock in that card, only show the state.
Confirm that it looks like this in your config:
    sensors:
      lock_frontdoor:
        device_class: lock
You’ll also need to restart Home Assistant after adding it.
Make sure your code is under binary_sensors: NOT sensors:
Your lock state will return locked or unlocked, which is not a valid state for a binary_sensor (on/off)
You therefore need to adjust your template as such (assuming on means unlocked here, amend as necessary)
    sensors:
      lock_frontdoor:
        device_class: lock
        value_template: "{{ states('lock.poly_control_danalock_v3_btze_locked') == 'unlocked' }}"
Ahaaa, that makes sense, thankyou!
Ah, my bad.
@lolouk44 and I couldn’t wait to test, despite that it’s past midnight, and it worked perfectly :grin:
sweet dreams. Don’t let the bed bugs bite you :laughing:
