Trying to figure out syntax for adding SmartThings
I have successfully connected my SmartThings to my Home Assistant setup, and I wonder if someone could validate if the format of the below syntax is the correct way to add things to Home Assistant please?
Sensor
  • platform: mqtt
    name: “Whatever I like - e.g. MQTT Front Door Sensor”
    state_topic: “smartthings/ExactNameOfSensorInSmartThings/sensor”
    command_topic: “smartthings/ExactNameOfSensorInSmartThings/sensor”
    payload_on: “on”
    payload_off: “off”
    retain: true
Switch
  • platform: mqtt
    name: “Whatever I like - e.g. MQTT Smart socket switch”
    state_topic: “smartthings/ExactNameOfSwitchInSmartThings/switch”
    command_topic: “smartthings/ExactNameOfSwitchInSmartThings/switch”
    payload_on: “on”
    payload_off: “off”
    retain: true
