I have been banging my head on this all morning and I just can not get it to work.
sensors:
front_door_state:
#value_template: '{% if is_state("sensor.frontdoor_alarm_level_2_1", "255") %}open{% else %}closed{% endif %}'
value_template: '{{states.sensor.frontdoor_alarm_level_2_1 | float > 0}}'
friendly_name: 'Front Door state'
The commented out is what I was using but that will not trigger an action that has a “for:” delay I guess it’s only for binary sensors as I found in another post.
My door sensors report 0 for closed and 255 for open. The above to get a “true/False” is only giving me a “false” no matter what state it is in, and trying to use the “open/closed” that does work never ever triggers if I have the “for:” delay in the trigger. if I remove that it works.
so how can I get the door lights to turn off 10 minutes after the door closes? is there a way to get a value to become a true binary so I can use the “for:” delay as seen below?
- id: front_door_closed_light
alias: FT_Door_closed
platform: state
entity_id: binary_sensor.front_door_state
to: 'false'
for:
hours: 0
minutes: 1
seconds: 0
- service: homeassistant.turn_off
entity_id: switch.patio_bulbs_switch_3_0
