I’m calling my webhook with
https://hassio.example.com/api/webhook/xxx but I’m getting the following response:
405: Method Not Allowed
- alias: mywebhookalias
- platform: webhook
webhook_id: xxx
- service: lock.toggle
entity_id: lock.front_door
What am I missing?
lolouk44
(lolouk44)
2
doc is incorrect and should be corrected by next release.
this is what you need in your trigger:
platform: event
event_type: ifttt_webhook_received
event_data:
action: keyword_you_set_in_IFTTT_body
see more here:
I’m trying to use the webhook trigger, not the IFTTT triggger.
awarecan
(Jason Hu)
4
Currently, webhook only support HTTP POST method, not GET
That was it. I used APITester.com and it’s working perfectly. Bye bye MQTT!
Can someone help me out in how the URL has to look like?
I tried https://hassio.example.com/api/event/ifttt_webhook_received but it didn’t seem to work.
Thanks for your help
I’m struggling with the same thing. How exactly did you solve this?
This is what I have as a test in the automation.yaml file.
- alias: 'webhook_test'
- platform: webhook
webhook_id: <webhook_id>
service: light.turn_on
entity_id: light.bedroom_light
I try to trigger it with the following webhook, but I get a 405 error.
https://<domain address>:443/api/webhook/<webhook_id>
This is probably your issue. See my post (above) about using the API Tester.
I wish they would add http post
Marius82
(Marius)
10
Can someone give me an example how to use the API Tester to post JSON data to the webhook?
lbsk31
(Gaetan)
11
Hi Marius82,
maybe you can try something like this :
{ “action”: “call_service”, “service”: “light.turn_on”, “entity_id”: “light.lumiere_du_living” }
