Trying to get air quality data from API
This is the data to be used
  - Temperature
  - Humidity
  - SolarInsolation
  - AirPressure
  - AirQuality
  - WindSpeed
  - NO2
  - SO2
  - O3
  - PM10
  - CO
  - NOx
  - PM2_5
{“StartTime”:"/Date(1518368400000+0100)/",“StopTime”:"/Date(1518372000000+0100)/",“Weather”:{“Temperature”:{“Value”:0.96,“Unit”:“°C”},“Humidity”:{“Value”:90.9,“Unit”:"%"},“SolarInsolation”:{“Value”:-0.28,“Unit”:“W/m2”},“AirPressure”:{“Value”:988.71,“Unit”:“hPa”},“WindSpeed”:{“Value”:5.98,“Unit”:“m/s”},“WindDirection”:{“Value”:121.54,“Unit”:“°”},“RainFall”:{“Value”:0.4,“Unit”:“mm”}},“AirQuality”:{“TotalIndex”:0.73,“NO2”:{“Value”:12.15,“Unit”:“ppb”,“Index”:0.3},“SO2”:{“Value”:4.58,“Unit”:“ppb”,“Index”:0.09},“O3”:{“Value”:43.2,“Unit”:“ppb”,“Index”:0.54},“PM10”:{“Value”:36.43,“Unit”:“µg/m3”,“Index”:0.73},“NOx”:{“Value”:11.85,“Unit”:“ppb”,“Index”:0.04},“PM2_5”:{“Value”:29.82,“Unit”:“µg/m3”,“Index”:1.19}}}
This is how i try to get the data:
Bookmarking as I have a similar problem getting data from my elec supplier.
The rest sensor allows you to import the entire json set to the sensor which can then be extracted out as attributes, but has a limit of 255 characters which falls well short of the 400 or so that I need.
Is there any other way to get the data?
Here’s something that you can use. It works in the template editor for me.
{%set value_json = {
	"StartTime": " / Date(1518368400000 + 0100) / ",
	"StopTime": " / Date(1518372000000 + 0100) / ",
	"Weather": {
		"Temperature ": {
			"Value ": 0.96,
			"Unit": "°C"
		"Humidity": {
			"Value": 90.9,
			"Unit": "%"
		"SolarInsolation": {
			"Value ": -0.28,
			"Unit": "W / m2"
		"AirPressure": {
			"Value ": 988.71,
			"Unit": "hPa"
		"WindSpeed": {
			"Value ": 5.98,
			"Unit": "m / s"
		"WindDirection": {
			"Value ": 121.54,
			"Unit": "°"
		"RainFall": {
			"Value": 0.4,
			"Unit ": "mm "
	"AirQuality": {
		"TotalIndex ": 0.73,
		"NO2": {
			"Value ": 12.15,
			"Unit": "ppb",
			"Index": 0.3
		"SO2": {
			"Value": 4.58,
			"Unit": "ppb",
			"Index": 0.09
		"O3": {
			"Value": 43.2,
			"Unit": "ppb",
			"Index": 0.54
		"PM10 ": {
			"Value ": 36.43,
			"Unit": "µg / m3",
			"Index": 0.73
		"NOx": {
			"Value": 11.85,
			"Unit": "ppb",
			"Index": 0.04
		"PM2_5": {
			"Value": 29.82,
			"Unit": "µg / m3",
			"Index": 1.19
{{ value_json.AirQuality.NO2['Value '] }}
Since i am new to this i feel stupid.
How to handle the non-static data from the API?
You can use it with a REST sensor (https://home-assistant.io/components/sensor.rest/).
I appreciate your pointing in the right direction, but I need some more anyway. In your example you have taken a value. How do I get on with units as well as how I get more values?
Oh now i think (hope) i get it.
- platform: rest
resource: http://data.goteborg.se/AirQualityService/v1.0/LatestMeasurement/XXX?format=json
method: GET
value_template: {{ value_json.AirQuality.NO2['Value '] }}
unit_of_measurement: "ppb"
You will also have to add resource where you can include the URL
Now i got it ^^
