Thanks!
So when I did that it crashed home assistant when I tried to reboot it.
does the username and password need to be bracketed? eg:
user_name: ‘username’
password: ‘password’
or no brackets
user_name: username
password: password
Here is the log with the errors.
2019-04-08 22:22:42 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=17 from 2019-04-09 02:34:42.660330)
2019-04-08 22:22:43 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
File "uvloop/handles/stream.pyx", line 827, in uvloop.loop.__uv_stream_on_read_impl
File "/usr/local/lib/python3.7/site-packages/pyenvisalink/envisalink_base_client.py", line 172, in data_received
result = handlerFunc(cmd['code'], cmd['data'])
File "/usr/local/lib/python3.7/site-packages/pyenvisalink/dsc_client.py", line 119, in handle_login
self.send_command(evl_Commands['Login'], self._alarmPanel.password)
File "/usr/local/lib/python3.7/site-packages/pyenvisalink/dsc_client.py", line 26, in send_command
self.send_data(to_send)
File "/usr/local/lib/python3.7/site-packages/pyenvisalink/envisalink_base_client.py", line 101, in send_data
_LOGGER.debug(str.format('TX > {0}', data.encode('ascii')))
UnicodeEncodeError: 'ascii' codec can't encode character '\u2019' in position 3: ordinal not in range(128)
2019-04-08 22:22:44 ERROR (MainThread) [pyenvisalink.envisalink_base_client] The server closed the connection. Reconnecting...
2019-04-08 22:22:44 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-04-08 22:22:52 WARNING (MainThread) [homeassistant.setup] Setup of envisalink is taking over 10 seconds.
2019-04-08 22:23:14 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
2019-04-08 22:23:14 ERROR (MainThread) [pyenvisalink.envisalink_base_client] The server closed the connection. Reconnecting...
2019-04-08 22:23:44 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
2019-04-08 22:23:44 ERROR (MainThread) [pyenvisalink.envisalink_base_client] The server closed the connection. Reconnecting...
2019-04-08 22:24:14 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
2019-04-08 22:24:14 ERROR (MainThread) [pyenvisalink.envisalink_base_client] The server closed the connection. Reconnecting...
2019-04-08 22:24:44 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
2019-04-08 22:24:44 ERROR (MainThread) [pyenvisalink.envisalink_base_client] The server closed the connection. Reconnecting...
2019-04-08 22:25:15 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
2019-04-08 22:25:15 ERROR (MainThread) [pyenvisalink.envisalink_base_client] The server closed the connection. Reconnecting...
2019-04-08 22:25:45 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport
