Trying to get Homebridge working on Mac OSX
Here is the error:
Hiltons-iMac:~ Hilton$ homebridge
[8/30/2016, 6:21:21 PM] Loaded plugin: homebridge-homeassistant
homebridge API version: 2
[8/30/2016, 6:21:21 PM] Registering platform 'homebridge-homeassistant.HomeAssistant'
[8/30/2016, 6:21:21 PM] ---
[8/30/2016, 6:21:21 PM] There was a problem reading your config.json file.
[8/30/2016, 6:21:21 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/local/lib/node_modules/homebridge/lib/server.js:176
    throw err;
SyntaxError: Unexpected token :
    at Object.parse (native)
    at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:170:19)
    at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:44:23)
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:409:26)
    at Object.Module._extensions..js (module.js:416:10)
    at Module.load (module.js:343:32)
    at Function.Module._load (module.js:300:12)
    at Function.Module.runMain (module.js:441:10)
Here is my config file:
"platforms": [
    "platform": "HomeAssistant",
    "name": "Home",
    "host": "http://192.168.0.101:8123",
    "password": "yourapipassword",
    "supported_types": ["light", "switch", "media_player", "scene", "rollershutter"]
I had to create the file. There was no config.json file in the Homebridge directory.
Please help, if possible.
Cheers
Hilton
Is that all you have in your config file? If so, you need to add an opening bracket { to the beginning of the file and a closing bracket } at the end.
So, it should look like this:
    "platforms": [
        "name": "Home",
Thank you. I’ll give it a try at the weekend.
