Hi. I have Home Assistant installed in a docker container on my Synology but I need it to work with Matter-Server which I have also installed. It turns out that matter devices only communicate through IPv6 and when I look at my container manager I see that for host, the IPv6 is disabled.
IPv6 is enabled on the Synology network interface so this is a docker/container manager set up issue.
Is there a guide for how to do this with container manager anywhere? I’ve see this guide for native docker Enable IPv6 support | Docker Docs but I am not sure now it relates to the Synology container manager version or even where the container manager files are located.
Help!
