This is my setup:
Installation method Home Assistant OS
Core 2025.10.4
Supervisor 2025.10.0
Operating System 16.2
Frontend 20251001.4
I have a SONOFF Universal Zigbee 3.0 USB Dongle Plus on /dev/ttyUSB0.
The dongle seems to be installed correctly - I see this in my Devices:
However, when I try and start the Zibee2MQTT Add-On, it will not start. And this is the log:
[19:13:55] INFO: Preparing to start...
[19:13:55] INFO: Socat not enabled
[19:13:55] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-10-25 19:13:57] info: z2m: Logging to console, file (filename: log.log)
[2025-10-25 19:13:57] info: z2m: Starting Zigbee2MQTT version 2.6.2 (commit #unknown)
[2025-10-25 19:13:57] info: z2m: Starting zigbee-herdsman (6.1.5)
[2025-10-25 19:13:57] info: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"20c5089fcb74ef1192dfc48c8fcc3fa0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_20c5089fcb74ef1192dfc48c8fcc3fa0-if00-port0","vendorId":"10c4","productId":"ea60"} => zstack: 4
[2025-10-25 19:13:57] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-10-25 19:13:57] error: z2m: Error while starting zigbee-herdsman
[2025-10-25 19:13:57] error: z2m: Failed to start zigbee-herdsman
[2025-10-25 19:13:57] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-10-25 19:13:57] error: z2m: Exiting...
[2025-10-25 19:13:57] error: z2m: Error: Error Resource temporarily unavailable Cannot lock port
… then gives up!
Running ls -l /proc/[0-9]/fd/ |grep /dev/ttyUISB0
As suggested in the “… fails to start” link, nothing is reported.
Any suggestions will be most welcome. As I have not got any Zigbee experience, I do not know what should & should not happen.
Regards, Martin
