Hi, I have HA installed on RPi4 no problems and all is running correctly for the GUI. I would like to add the HACS integration so need to access the folder via IP i believe. installed the Samba Add On no problems i think. However when i try to access the folder structure on my mac using smb://my IP i get the request for username and password, which i assumed would be the same as i used to access HA but this doesnt work. Any pointers would be welcome. Thanks
No, it will be the credentials you set up in the SAMBA add-on configuration.
Thanks Tom. - perfect
