Trying to make blueprint - only one of the conditions triggered
i’m trying to make a blueprint for ikea tradfri wireless dimmer and i have it working for reducing brightness but not the other way around.
I’m wondering if someone can spot what is wrong.
Current version is at blueprint for ikea tradfri wireless dimmer · GitHub
the triggers should just be 1,195 and 0,195 and I see them in the zha_events but for some reason only 1,195 are making its way trhough.
Can you please show the data for the two events?
Sure, it generates quite a few events - i’ll paste both “blocks” of data, here is for turning right:
zha_event
event_type: zha_event
    device_ieee: 00:0b:57:ff:fe:92:8a:53
    unique_id: 00:0b:57:ff:fe:92:8a:53:1:0x0008
    device_id: 6d728905ca4ac0db750bdf1d1f0c3ffa
    endpoint_id: 1
    cluster_id: 8
    command: move_with_on_off
    args:
       -  0
       -  70
origin: LOCAL
time_fired: '2021-01-05T10:59:26.370612+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  70
origin: LOCAL
time_fired: '2021-01-05T10:59:26.402001+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  70
origin: LOCAL
time_fired: '2021-01-05T10:59:26.434400+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  70
origin: LOCAL
time_fired: '2021-01-05T10:59:26.465983+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  70
origin: LOCAL
time_fired: '2021-01-05T10:59:26.498116+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: stop
    args: []
origin: LOCAL
time_fired: '2021-01-05T10:59:26.530168+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: stop
    args: []
origin: LOCAL
time_fired: '2021-01-05T10:59:26.561629+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  70
origin: LOCAL
time_fired: '2021-01-05T10:59:26.593727+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: move_to_level_with_on_off
    args:
       -  255
       -  1
origin: LOCAL
time_fired: '2021-01-05T10:59:26.625845+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  255
       -  1
origin: LOCAL
time_fired: '2021-01-05T10:59:26.657949+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  255
       -  1
origin: LOCAL
time_fired: '2021-01-05T10:59:26.689465+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  255
       -  1
origin: LOCAL
time_fired: '2021-01-05T10:59:26.721846+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  255
       -  1
origin: LOCAL
time_fired: '2021-01-05T10:59:27.410090+00:00'
context:
    parent_id:
    user_id:
and here is when turning left:
    endpoint_id: 1
    cluster_id: 8
    command: move
    args:
       -  1
       -  195
origin: LOCAL
time_fired: '2021-01-05T11:01:12.666579+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: move
    args:
       -  1
       -  195
origin: LOCAL
time_fired: '2021-01-05T11:01:12.697422+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: move
    args:
       -  1
       -  195
origin: LOCAL
time_fired: '2021-01-05T11:01:12.729716+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: move
    args:
       -  1
       -  195
origin: LOCAL
time_fired: '2021-01-05T11:01:12.761262+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: move
    args:
       -  1
       -  195
origin: LOCAL
time_fired: '2021-01-05T11:01:12.793320+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    command: move
    args:
       -  1
       -  195
origin: LOCAL
time_fired: '2021-01-05T11:01:12.833251+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  1
origin: LOCAL
time_fired: '2021-01-05T11:01:12.873200+00:00'
context:
    parent_id:
    user_id:
    endpoint_id: 1
    cluster_id: 8
    args:
       -  0
       -  1
origin: LOCAL
time_fired: '2021-01-05T11:01:13.705823+00:00'
context:
    parent_id:
    user_id:
you’ll see right is a move or move_with_on_or_off 0,195 and left is same but with 1,195.
hmm - now that see this capture it looks like 0,70 is the right one …that is just weird as https://github.com/zigpy/zha-device-handlers/blob/61dedab318a8986b2b0a7bffe5116bbc40bed214/zhaquirks/ikea/dimmer.py says it shuoldn’t…
let me try 0,70 :wink:
btw. does blueprints autoreload or is restart needed for changes to take effect?
That’s what I wanted to point out, I can’t see 0, 195 :slight_smile:
Reload automations shouöd be enough.
yeah, figured out reload but even when changing to look for 0, 70 its not being picked up. and i can’t spot why
Hmm that’s strange, sorry can’t help here as I don’t use ZHA.
now just made the only change of of 1, 195 to 0, 195 and now it picks it up.
so it does see the event but for some reason the second condition is not triggered.
I don’t think it is zha specific here though - must be some bug in the condition matching …either in HA or in my automatoin…but I can’t spot it :wink:
I see different structure for the ‘args:’ for different devices, could this be a problem? For example the Aqara Cube is ‘KV’-like, where others just have the values, no keys, for args:
    args:
        value: 81.0
        flip_degrees: 90
        activated_face: 2.0
you can see the values above in my earlier post - its just a list of values:
 args:
       -  0
       -  1
and exact same structure and I can get it to match/trigger if I change the first condition section, but the seocnd one just seem to get ignored.
