I just wanted to see how easy the migration process is and test the stability but it seems that I ran into a little issue. Creating the config, uploading and having the new switches in HA seemed to work quite well. Also got the log messages that told me that everything worked. Only issue was that there was no physical reaction. So my guess is that there is some kind of a mapping problem of the pins.
In tasmota was using this config:
Which I migrated to this yaml file (only switch/input config included):
esphomeyaml:
platform: ESP8266
board: nodemcuv2
Well that doesn’t explain why you would switch from something working just for shits and giggles hence asking what advantage there would be to switching…
Not necessarily… I always run the betas for instance but changing to a different implementation of something… well I need a good reason to do that…
Good reason for me is that esphomelib seems to be more expandable (modular design from the start). This is probably not important to you if all your sensors are integrated in tasmota.
Also doing automations through rules in tasmota currently feels a bit hard to understand and manage.
