I’m trying to mount a remote share (where my CCTV is stored) and I keep getting a Permission Denied error, depite being root.
core-ssh:~# mount //192.168.1.1/USB_HDD_1/ /mnt/cctv/
mount: permission denied (are you root?)
I want to be able to access those images to attach them to notifications when the CCTV is triggered, but putting the share directly into config also gives an error:
2018-04-08 03:03:48 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: not a directory @ data['whitelist_external_dirs'][0]. Got '//192.168.1.1/USB_HDD_1/Video/CCTV/'. (See /config/configuration.yaml, line 2).
What’s the correct way to mount a remote directory so Home Assistant can see it when using Hass.io?
So let’s start with the fact that you are in an SSH docker container, that is NOT the hassio container, and not the host OS.
What protocol are you trying to mount? Linux supports several protocols, so just saying // doesn’t tell the system what protocol you are trying to use. NFS? SMB? SSHFS? Does the SSH container even support any of those protocols? Is the appropriate FUSE system installed and available for such a thing?
I’m trying to connect using cifs, the command I pasted was just one of a few I tried, but I should have used the right version for what I was trying to do.
I run the mount command from a shell_command out from a automation at startup.
And I edit the shell_command via “File editor” add-on and reboot home assistant on each change.
