I want to get this value (here taken from the MQTT-stream): climate/thermofloor_as_heatit_thermostat_tf_021_dry_air/temperature
In this case the value is 22, but I just can’t seem to get it into my code. This is what I’m trying to use:
"payload_template": "{{states.climate.thermofloor_as_heatit_thermostat_tf_021_dry_air.temperature}}",
"topic": "eg/Termostat.Setpoint"
But I’m not getting anything from that. If I add “.state” at the end, the code doesen’t work at all. I have this working, from the info climate/thermofloor_as_heatit_thermostat_tf_021_dry_air/state
"payload_template": "{{states.climate.thermofloor_as_heatit_thermostat_tf_021_dry_air.state}}",
"topic": "eg/Termostat.modus"
That correctly shows the current mode, which is “heat”. So why isn’t the other code working in the same way?
