I installed InfluxDB from the Github then after reading the Hassio instructions it said use the add-on dont use the repository!!!
How do I uninstall now?
How did you install it?
I used the GitHub windows explorer to clone it.
And then what? Surely you must have done more than that? Software doesn’t just start if you clone it from github.
Then I also installed it from the addon. Then tried to run it it tried to load but no success, just a black screen.
f all you did was clone the github repo, then just delete the cloned directory.
problem is its on hass.io which has limited ssh commands and if i try to delete through samba ang windows explorer it wont let me.
hassio has full commands. rm is included.
I could’nt find that but was able to delete through explorer in the end. Many thanks for all your help.
