Trying to retain an MQTT value
Greetings
My core issue is with a counter being reset to 0 when my Wemos D1 mini reboots, I need it to retain the last value. This seems to be an issue with the native API and I’ve turned to MQTT and it’s retain feature but I cannot get that to work.
My pseudo idea is to have the D1 read a photoresistor voltage and if it’s above 0.9V trigger a counter that will count the amount of time, calculate the fuel usage and publish that as totalOil over MQTT. This publish needs to be retained so I can later figure out how to retrieve the latest value from MQTT on reboot.
Any suggestions on why my retain isn’t working would be appreciated.
/Fredrik
mqtt:
  broker: x.x.x.x
  username: !secret mqttlogin
  password: !secret mqttpass
  topic_prefix: homeassistant/esp
  discovery_prefix: homeassistant
  birth_message:
  will_message:
globals:
  - id: totalOil
    type: float
    restore_value: no
  - platform: mqtt_subscribe
    #name: "Data from topic"
    topic: homeassistant/esp/sensor/oljeforbrukning/state
  - platform: adc
    pin: A0
    update_interval: 1s
    retain: true
    expire_after: 10 minutes
    lambda: |-
     static float num_executions;
     id(totalOil) = id(mysensor).state;
      if (id(Burner).state>0.9) {
        num_executions +=1;
      id(totalOil) +=  (num_executions/3600)*0.84;
      return id(totalOil);
    unit_of_measurement: 'l'
    update_interval: 1s
    retain: true
Does it work to seed the value on_boot with an mqtt sensor.
Hi nickrout
My though exactly but it doesn’t seem to work. Even if I manually set the state of homeassistant/esp/sensor/oljeforbrukning/state it still goes to “nan” efter the Wemos finishes it’s boot.
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    - priority: 250.0
      then:
        - script.execute: power_on_boot
script:
  - id: power_on_boot
    then:
      - lambda: |-
          static float oil;
          oil = id(mysensor).state;
          ESP_LOGI("main", "Boot value of oil: %f", oil);
          ESP_LOGI("main", "Boot value of totalOil: %f", id(totalOil));
At level 250 the mqtt won’t be set up. ESPHome Core Configuration — ESPHome
Is this as simple as restore from flash? ESPHome Core Configuration — ESPHome
Maybe, but isn’t writing fast changes to flash illadviced?
I’ve been fiddling with my code back and forth and the issue as it is right now is “nan” being sent right after the D1 regains WIFI after a boot or config change.
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    - priority: 200.0
      then:
# Enable logging
logger:
  level: DEBUG
ota:
mqtt:
  broker: 172.16.80.10
  birth_message:
  will_message:
api:
globals:
  - id: totalOil
    type: float
    restore_value: no
script:
  - id: power_on_boot
    then:
      - lambda: |-
          static float oil;
  - platform: adc
    pin: A0
    update_interval: 10s
    retain: true
    lambda: |-
     static float num_executions = 0;
        num_executions +=1;
        ESP_LOGI("main", "Executions: %f", num_executions);
      if (num_executions < 0.7) {
       ESP_LOGI("main", "0 Executions");
      ESP_LOGI("main", "Value of totalOil before publish: %f", id(totalOil));
    retain: true
