I am trying to run an automation with Alexa, what is the best way to do this?
Emulated hue can trigger scripts, turn lights on or off.
The Alexa component isn’t too hard to set up if you’ve already for SSL working and can access your HA install from outside your network.
You’ve got a couple of options:
Emulated Hue (as @ih8gates mentioned)
HAASKA
IFTTT
Setting up your own intents
If you decide to go the last route - which is how I go for most of my stuff - check out this great tutorial by @aimc
and this one by @bruhautomation
thanks! using the emulated hue and it is working pretty well so far
