I’m building an indicator that sets a red, yellow, or green light to illuminate depending on the state of a distance sensor. I have that part working well, but what I’d like to do is to only enable the leds when the light to that room is on in Home Assistant so the leds aren’t on all day or night long when no one is there. Here’s my yaml where I’m having trouble getting the switch value from Home assistant, can anyone point me in the right direction to get this working? Thanks
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "111111111111111="
ota:
password: "11111111111"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Dust-Collector-Level"
password: "11111111"
web_server:
port: 80
time:
- platform: homeassistant
captive_portal:
i2c:
globals:
- id: led_enabled
type: bool
restore_value: no
initial_value: "false"
switch:
- platform: restart
light:
- platform: binary
output: dust_light_output_g
- platform: binary
output: dust_light_output_y
- platform: binary
output: dust_light_output_r
output:
- id: dust_light_output_g
platform: gpio
pin: D5
- id: dust_light_output_y
platform: gpio
pin: D6
- id: dust_light_output_r
platform: gpio
pin: D7
- platform: uptime
- platform: wifi_signal
name: dust-collector-level WiFi Signal
update_interval: 60s
entity_id: switch.garage_light
internal: false #switch this to true once it's working
on_value:
then:
- globals.set:
value: !lambda return id(led_switch).state;
#I'm getting an error grabbing the value here
- platform: vl53l0x
update_interval: 1s
filters:
- sliding_window_moving_average:
send_every: 5
window_size: 10
on_value:
then:
- if:
condition:
lambda: |-
return id(led_enabled).state == false;
then:
- light.turn_off: light_red
- light.turn_off: light_yellow
- light.turn_off: light_green
else:
- if:
condition:
lambda: |-
return id(dc_measure_level).state > 0.35;
then:
- light.turn_on: light_green
else:
- if:
condition:
lambda: |-
return id(dc_measure_level).state < 0.18;
then:
- light.turn_on: light_red
else:
- light.turn_on: light_yellow
text_sensor:
- platform: version
name: dust-collector-level ESPHome Version
- platform: wifi_info
ip_address:
ssid:
bssid:
