I got the automation working.
Here is the flow if someone has a similar problem.
[{"id":"542304b23c76704f","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"ed558064e11fc7b3","type":"server-state-changed","z":"542304b23c76704f","name":"Air Balcony","server":"14819af3.534ef5","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.particulate_matter_2_5um_concentration","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":150,"y":120,"wires":[["6414a766cce67880","8b8d647651988a81"]]},{"id":"8b8d647651988a81","type":"function","z":"542304b23c76704f","name":"First Function","func":"global.set(\"sensor1\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":80,"wires":[["3afacbb1a57ae17d"]]},{"id":"3afacbb1a57ae17d","type":"debug","z":"542304b23c76704f","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":660,"y":80,"wires":[]},{"id":"21e971c3e87a82b5","type":"api-call-service","z":"542304b23c76704f","name":"Assi-Alarm","server":"14819af3.534ef5","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_b3n_phone","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\"Balkon ist vergifted\",\"title\":\"Assi-Alarm\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1150,"y":140,"wires":[[]]},{"id":"6414a766cce67880","type":"delay","z":"542304b23c76704f","name":"","pauseType":"delay","timeout":"60","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":320,"y":140,"wires":[["7361048a0bf4a83c"]]},{"id":"7361048a0bf4a83c","type":"function","z":"542304b23c76704f","name":"Second Function","func":"// get the value of the first sensor from the global variable\nvar sensor1 = global.get(\"sensor1\");\n\n// subtract the value of the second sensor from the first sensor\nvar result = sensor1 - msg.payload;\n\n// check if the result is greater than 18\nif (result > 18) {\n // return true if the result is greater than 20\n msg.payload = true;\n} else {\n // return false if the result is not greater than 20\n msg.payload = false;\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":140,"wires":[["34b030c9d560a730"]]},{"id":"34b030c9d560a730","type":"StatusUltimate","z":"542304b23c76704f","name":"Status","property":"payload","x":670,"y":140,"wires":[["e517aedb3ddb33a4"]]},{"id":"e517aedb3ddb33a4","type":"switch","z":"542304b23c76704f","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":790,"y":140,"wires":[["b6b691d2d3b1e3b2"],[]]},{"id":"b6b691d2d3b1e3b2","type":"delay","z":"542304b23c76704f","name":"","pauseType":"rate","timeout":"10","timeoutUnits":"minutes","rate":"1","nbRateUnits":"10","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":960,"y":140,"wires":[["21e971c3e87a82b5"]]},{"id":"14819af3.534ef5","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
I am going the replace the notification with some LEDs at the balcony door in the future.
