I am following the official guide here to switch Z-Wave - Home Assistant
I disabled (not uninstalled) the integration then for step 3 it says “Install and configure the Z-Wave JS to MQTT add-on, including setting the location of your Z-Wave device and the network security keys.”
I installed the addon but cannot find how to configure it, under configuration tab it states " This add-on does not expose configuration for you to mess with… ". So, I tried start the addon figuring maybe it has a web interface but it does not start and keeps going back to stopped, logs below.
Any ideas, are these docs I am following correct?
Thanks!
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: Z-Wave JS to MQTT
Fully configurable Z-Wave JS to MQTT gateway and control panel; based on Zwavejs2Mqtt
Add-on version: 0.45.0
You are running the latest version of this add-on.
System: Home Assistant OS 8.4 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2022.8.2
Home Assistant Supervisor: 2022.08.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/configuration.sh
cont-init: info: /etc/cont-init.d/configuration.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun zwavejs2mqtt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[12:35:35] INFO: Starting the Z-Wave JS to MQTT...
2022-08-11 12:35:40.110 INFO APP: Version: 6.15.2
2022-08-11 12:35:40.120 INFO APP: Application path:/opt
______ _ ___ _ _
|___ / (_) |__ \ | | | |
/ /_ ____ ___ _____ _ ___ ) |_ __ ___ __ _| |_| |_
/ /\ \ /\ / / _` \ \ / / _ \ / __| / /| '_ ` _ \ / _` | __| __|
/ /__\ V V / (_| |\ V / __/ \__ \/ /_| | | | | | (_| | |_| |_
/_____|\_/\_/ \__,_| \_/ \___| |___/____|_| |_| |_|\__, |\__|\__|
_/ | | |
|__/ |_|
2022-08-11 12:35:40.180 WARN STORE: scenes.json not found
2022-08-11 12:35:40.185 WARN STORE: nodes.json not found
2022-08-11 12:35:40.193 WARN STORE: users.json not found
2022-08-11 12:35:40.274 INFO APP: Listening on port 44920 host 0.0.0.0 protocol HTTP
2022-08-11 12:35:40.514 INFO MQTT: MQTT is disabled
2022-08-11 12:35:40.525 WARN BACKUP: Store backup is disabled
2022-08-11 12:35:40.528 WARN BACKUP: Nvm backup is disabled
[12:35:40] INFO: Starting NGinx...
2022-08-11 12:35:40.534 WARN ZWAVE: Zwave driver not inited, no port configured
