I’m running HA on docker with supervisor on ubuntu server 20.04.
Home Assistant 2022.11.4
Supervisor 2022.11.2
everything was working fine up until a couple of days ago when I tried to update the HA from the UI and got the following notification:
’ failed to call update/install. error updating Home assistant core blocked from execution, no host internet connection.’
what did I tried:
- I have tried to reboot the system (and the host) - didn’t helped.
- adding DNS in /etc/systemd/resolved.conf. didn’t helped
- changing the network settings inside HA (adding DNS), gave me the following error: ‘Unknown error, see supervisor logs’
supervison full log after the error:
raise value
File "/usr/local/lib/python3.10/site-packages/sentry_sdk/integrations/aiohttp.py", line 116, in sentry_app_handle
response = await old_handle(self, request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 138, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 204, in token_validation
File "/usr/src/supervisor/supervisor/api/utils.py", line 62, in wrap_api
answer = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/network.py", line 192, in interface_update
body = await api_validate(SCHEMA_UPDATE, request)
File "/usr/src/supervisor/supervisor/api/utils.py", line 151, in api_validate
data_validated = schema(data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 387, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
return schema(data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 110, in __call__
if not self.msg and Enum and issubclass(self.type, Enum):
TypeError: issubclass() arg 1 must be a class
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/input/mouse1 - None
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/input/event6 - /dev/input/by-id/usb-Atmel_Atmel_maXTouch_Digitizer-event-if00
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/input/mouse2 - /dev/input/by-id/usb-Atmel_Atmel_maXTouch_Digitizer-mouse
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/input/event7 - /dev/input/by-id/usb-Atmel_Atmel_maXTouch_Digitizer-event-mouse
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/usb/hiddev0 - None
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/hidraw0 - None
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/usb/hiddev1 - None
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/hidraw1 - None
22-12-04 22:35:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.REMOVE hardware /dev/bus/usb/001/008 - None
22-12-04 22:35:55 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/sentry_sdk/integrations/aiohttp.py", line 126, in sentry_app_handle
reraise(*_capture_exception(hub))
File "/usr/local/lib/python3.10/site-packages/sentry_sdk/_compat.py", line 56, in reraise
raise value
File "/usr/src/supervisor/supervisor/api/network.py", line 221, in interface_update
await asyncio.shield(self.sys_host.network.apply_changes(interface))
File "/usr/src/supervisor/supervisor/host/network.py", line 225, in apply_changes
settings = get_connection_from_interface(interface)
File "/usr/src/supervisor/supervisor/dbus/network/setting/generate.py", line 127, in get_connection_from_interface
"ssid": Variant("ay", interface.wifi.ssid.encode("UTF-8")),
AttributeError: 'NoneType' object has no attribute 'ssid'
22-12-04 22:35:59 ERROR (MainThread) [aiohttp.server] Error handling request
raise value
