Trying to use a magnetic / contact sensor with OpenGarage
I’ve posted in the OpenGarage forums as well, but have seen several threads here about OpenGarage so I thought I’d try my luck here as well…
I’ve been wrestling with this over the early part of this Easter weekend and am clearly out of my depth. I’m hoping someone here has the knowledge to point out where I’m going wrong.
I’m trying replace an existing GogoGate 2 device with an OpenGarage (running 1.0.8 firmware) so I can link it into HomeAssistant setup.
My plan was to re-use the existing door magnetic sensor rather than the distance sensor (as the garage door is a compact roller) which I believe is supported in the latest OpenGarage firmware.
My understanding was that the sensor needs to be connected to GPI04 and GND to work, however I’ve tested and see no change in OpenGarage door state when opening and closing the door.
I’ve not found anything further online to help me understand where I’m going wrong with this, but I suspect I’m using the wrong pins.
Is anyone using this particular approach and able to help me out?
My skills are rather limited in this area and I’m beginning to feel I’ve bitten off more than I can chew, so any help would be appreciated…
