So i’m trying to set a location (yes it’s sleeping, but it could be a location)
my automation is below
- alias: 'Set Arya Sleeping'
platform: state
entity_id: binary_sensor.esp3_door
to: 'on'
- service: device_tracker.see
dev_id: device_tracker.123456
location_name: 'Sleeping'
I get the following error.
File "/usr/local/lib/python3.6/dist-packages/homeassistant/components/device_tracker/__init__.py", line 224, in async_see_service
yield from tracker.async_see(**data)
File "/usr/local/lib/python3.6/dist-packages/homeassistant/components/device_tracker/__init__.py", line 291, in async_see
dev_id = cv.slug(str(dev_id).lower())
File "/usr/local/lib/python3.6/dist-packages/homeassistant/helpers/config_validation.py", line 339, in slug
raise vol.Invalid('invalid slug {} (try {})'.format(value, slg))
voluptuous.error.Invalid: invalid slug device_tracker.123456 (try device_tracker123456)
if i then set it to device_tracker123456 i get no error, but also the location doesn’t change.
I found a few links which may indicate the device_tracker.see my be broken…
https://community.home-assistant.io/t/using-device-tracker-see/20856
https://community.home-assistant.io/t/device-tracker-see-doesnt-actually-change-state/5052
