Trying to use 'choose' based on the trigger
I have the following code, but it’s not working or working unpredictably. I basically just want to use the choose option to do one of two things (this will be one of 8 things, hence choose) based on which input_boolean entity turning on, triggered it.
    - platform: state
      entity_id:
        - input_boolean.ib1
        - input_boolean.ib2
      to: "on"
  condition:
    condition: time
    weekday:
      - sun
      - sat
      - fri
      - mon
    - choose:
        # IF 1
        - conditions:
            - condition: template
              value_template: "{{ trigger.to_state_object_id == ib1 }}"
          sequence:
            - service: notify.telegram_justin
                message: ib1
    - choose:
        # IF 2
        - conditions:
              value_template: "{{ trigger.to_state_object_id == ib2 }}"
          sequence:
                message: ib2
You have a couple issues with your template:
  1. trigger.to_state_object_id is not valid.
  2. Without quotes, ib1 is interpreted as a variable with no defined value.
It should be as follows:
value_template: "{{ trigger.to_state.object_id == 'ib1' }}"
Full Automation
    - platform: state
      entity_id:
        - input_boolean.ib1
        - input_boolean.ib2
      to: "on"
  condition:
    condition: time
    weekday:
      - sun
      - sat
      - fri
      - mon
    - choose:
        - conditions:
          sequence:
                message: ib1
        - conditions:
              value_template: "{{ trigger.to_state.object_id == 'ib2' }}"
          sequence:
                message: ib2
Or, if that is all you’re trying to do, you don’t really need the Choose:
        message: "{{ trigger.to_state.object_id }}"
Brilliant spots, clearly been a long week, two typos in one template. Thanks very much, working as it should be now.
