IngeJones
(Inge Jones)
September 3, 2024, 4:48pm
1
I want to use the File integration so that I can create and write to my own logfile.
It appears to me that the addition to the configuration.yaml doesn’t do anything because the integration was not installed - however the integration won’t install unless I give it a valid file path - which I can’t do until the configuration file is accepted. I ran the configuration check and restarted home assistant so I don’t believe there is anything wrong with my syntax
jchh
((not John))
September 3, 2024, 4:55pm
2
Hi - you posted twice. Here is the other one. Can you please delete this one?
[Screenshot 2024-09-03 17.40.24]
[S…
petro
(Petro)
September 3, 2024, 5:00pm
3
You must have set up external dirs incorrectly. Your logs show that. What did you try?
@jchh I don’t see duplicates. You just linked to this post, are you sure you weren’t running into a browser issue?
IngeJones
(Inge Jones)
September 3, 2024, 5:01pm
4
Your link just sends me back to here. I can’t find another post I’ve made
jchh
((not John))
September 3, 2024, 5:07pm
5
Sorry, both - I could have sworn I saw 2 versions, 2 minutes apart - I assumed it somehow posted twice.
Please accept my apologies.
IngeJones
(Inge Jones)
6
I’ll try adding the "homeassistant: " line as in
homeassistant:
allowlist_external_dirs:
- “/config”
I assumed that would have been already done higher up in the hierarchy. I’ll let you know if that helps
IngeJones
(Inge Jones)
September 3, 2024, 5:19pm
8
Ok sorted, my fault for making an assumption!
