This is my first post. I have been using ha for about 5 years now and have managed to get this far.
My problem now is I purchased some tuya, wifi, battery door sensors. To preserve battery life, they become unavailable shortly after they report a “state change”. It does appear that every once in a while they wake up and report in.
So what I wanted to do, is keep their state locally so I created accompanying input_boolean for each sensor. IE: binary_sensor.front_door => input_boolean.st_front_door.
Since I will have about 12 of these suckers, I wanted to create a trigger to handle all 12.
The trigger works pretty good, but I wanted to add a condition to not attempt to change the stated, if it hasn’t changed. (Condition 2 below) But I find the proper bracketing/quoting to make it happen.
Any insight would be appreciated.
Thanks.
- id: '1675698867270'
alias: "Trigger for door traps"
description: When a door trap changes state, set a corresponding input_boolean to hold the state
- platform: state
entity_id:
- binary_sensor.glass_wall
- binary_sensor.master_slider
- binary_sensor.guest_slider
- binary_sensor.front_window
condition:
condition: and
conditions:
# 1) make sure we are not going to try and change the state to "unavailable"
- condition: template
value_template: '{{ trigger.to_state.state in [''on'',''off''] }}'
# 2) only change the state holder if the state truly changed.
value_template: "{{ ((trigger.to_state.state)) != {{input_boolean.st_((trigger.to_state.attributes.friendly_name)).state}} }}"
- service: input_boolean.turn_{{trigger.to_state.state}}
data_template:
entity_id: input_boolean.st_{{trigger.to_state.attributes.friendly_name}}
- service: notify.email_bb
title: Trigger for door traps
message: "Setting input_boolean.st_{{trigger.to_state.attributes.friendly_name}} to {{trigger.to_state.state}}"
mode: single
I was not aware that you could have multiple “to:” values so that’s a plus but the other condition is to stop false triggers. It seems that the sensors from time to time wake up and broadcast their state, so by evaluating the sensor state to the “last recorded state” it just avoids calling the actions for nothing.
Try it. I don’t believe that your sensors republishing the same state will trigger my trigger.
They might have triggered your original if they have attributes that were updated too, but with to: etc specified, it should only trigger on a genuine state change between on and off, in either direction.
I noticed (after a cup of coffee) that this morning when I opened a few doors and I did not get notified. So I think the original condition will prevent unwanted notifications.
