Trying to use the Get Entities node to pass a temperature value to Alexa Speak
Hi still very new to Node-Red I have a temperature sensor on a ESP Home Device in the garage.
ID is “sensor.garage_temperature”
Trying to get that in Node-Red, but struggling. I thought the new(ish) Get Entities node would be ideal.
I want to use that temperature value is a Alexa speak sentence.
Many thanks in anticipation
Regards Dave
You dont need the get entities node for that. Simply a normal state node will do.
Get Entities is cool when you want to get several entities that you define in the node. i.e.: Every sensor that has the name brightness in it and is above 50lux.
In you case, a current state node will give you the value of the sensor. You can then just use the message with Alexa
Yes, do a Get State for the entity, then use {{payload}} to have Alexa say the temp.
Many thanks, have tried that and payload = Temperature.
What node do I need to add the get the payload added to some text i.e. "The garage Temperature is " payload
Regards Dave
In the call service node that you speak the message:
  message: "The garage temperature is {{payload}} degrees",
Brilliant no place for it in the “Routine Speak” node so put in a template.
<speak>
</speak>
One again, thank you all for your help
Regards Dave
Just use the Call Service node, with data looking something like this:
    "message": "Please close the following doors and windows. {{payload}}.  Good night.",
    "data": {
        "type": "tts"
    "target": [
        "{{data.state}}"
This assumes you’re using AMP tho, and maybe you aren’t.
Hi I am using “node-red-contrib-alexa-remote2-applestrudel” as my way of getting Alexa to speak
Re Dave
