I’m trying to debug why my home assistant has started restarting regularly.
It is running on a pi4, 4GB RAM, with a 500GB SSD
Home Assistant 2022.12.8
Supervisor 2022.12.1
Operating System 9.4
Frontend 20221213.1 - latest
But currently it is restarting up to every few minutes.
The logs seem to show:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/http.py:132
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 23:45:51 (333 occurrences)
Last logged: 23:45:53
[548337876272] Client exceeded max pending messages [2]: 2048
Looking in the logs, with the http api in debug mode, there are a lot of messages:
2022-12-29 23:35:01.796 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547422689776] Sending {"id":218,"type":"event","event":{"event_type":"state_changed","data":{"entity_id":"sensor.rubicson_42_01_temperature","old_state":{"entity_id":"sensor.rubicson_42_01_temperature","state":"4.2","attributes":{"state_class":"measurement","event":"0a520a1e4201002a150269","unit_of_measurement":"°C","assumed_state":true,"device_class":"temperature","friendly_name":"Fridge"},"last_changed":"2022-12-29T23:34:04.774128+00:00","last_updated":"2022-12-29T23:34:04.774128+00:00","context":{"id":"01GNG3RN76QCQ24VG3CYAM2VBD","parent_id":null,"user_id":null}},"new_state":{"entity_id":"sensor.rubicson_42_01_temperature","state":"4.2","attributes":{"state_class":"measurement","event":"0a520a224201002a150279","unit_of_measurement":"°C","assumed_state":true,"device_class":"temperature","friendly_name":"Fridge"},"last_changed":"2022-12-29T23:35:01.765385+00:00","last_updated":"2022-12-29T23:35:01.765385+00:00","context":{"id":"01GNG3TCW5YNTA5RS6NTN2AEA4","parent_id":null,"user_id":null}}},"origin":"LOCAL","time_fired":"2022-12-29T23:35:01.765385+00:00","context":{"id":"01GNG3TCW5YNTA5RS6NTN2AEA4","parent_id":null,"user_id":null}}}
2022-12-29 23:35:01.797 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547422689776] Sending {"id":218,"type":"event","event":{"event_type":"rfxtrx_event","data":{"packet_type":82,"sub_type":10,"type_string":"Rubicson","id_string":"42:01","data":"0a520a224201002a150279","values":{"Temperature":4.2,"Humidity":21,"Humidity status":"normal","Humidity status numeric":2,"Battery numeric":9,"Rssi numeric":7},"device_id":"fbd0b476735c0ec363eb99e836811bb6"},"origin":"LOCAL","time_fired":"2022-12-29T23:35:01.785305+00:00","context":{"id":"01GNG3TCWSETTASRXXMWMS6RTX","parent_id":null,"user_id":null}}}
2022-12-29 23:35:01.798 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547377908608] Sending [{"id":21,"type":"event","event":{"c":{"sensor.rubicson_42_01_battery":{"+":{"lc":1672356901.763172,"c":"01GNG3TCW33FS79TNW8A86ACG2","a":{"event":"0a520a224201002a150279"}}}}}},{"id":21,"type":"event","event":{"c":{"sensor.rubicson_42_01_signal_strength":{"+":{"s":"-64","lc":1672356901.764008,"c":"01GNG3TCW4RYA777R0EFFMH1ZN","a":{"event":"0a520a224201002a150279"}}}}}},{"id":21,"type":"event","event":{"c":{"sensor.rubicson_42_01_humidity":{"+":{"lc":1672356901.764475,"c":"01GNG3TCW46686WR7M3A1N0DGN","a":{"event":"0a520a224201002a150279"}}}}}},{"id":21,"type":"event","event":{"c":{"sensor.rubicson_42_01_humidity_status":{"+":{"lc":1672356901.764951,"c":"01GNG3TCW441Y3RGTK6KPG5647","a":{"event":"0a520a224201002a150279"}}}}}},{"id":21,"type":"event","event":{"c":{"sensor.rubicson_42_01_temperature":{"+":{"lc":1672356901.765385,"c":"01GNG3TCW5YNTA5RS6NTN2AEA4","a":{"event":"0a520a224201002a150279"}}}}}}]
2022-12-29 23:35:01.836 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547422689776] Sending {"id":218,"type":"event","event":{"event_type":"call_service","data":{"domain":"homeassistant","service":"restart","service_data":{}},"origin":"LOCAL","time_fired":"2022-12-29T23:35:01.835752+00:00","context":{"id":"01GNG3TCYB0PYB29XQFH38BRJV","parent_id":null,"user_id":"09f6687f64a04b91afb8a1f69d609b0a"}}}
2022-12-29 23:35:01.992 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [547422689776] Sending {"id":218,"type":"event","event":{"event_type":"homeassistant_stop","data":{},"origin":"LOCAL","time_fired":"2022-12-29T23:35:01.991781+00:00","context":{"id":"01GNG3TD37H50FZHQV0TTAWFWA","parent_id":null,"user_id":null}}}
But nothing obviously invalid
The supervisor logs show the restart, but I can’t so far track down what has triggered it:
22-12-29 23:10:07 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
Then nothing for 5 minutes, then:
22-12-29 23:15:02 INFO (SyncWorker_7) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/raspberrypi4-64-homeassistant
The vast majority of the API calls in the log are state updates for all the parameters of all the devices in the house
