Hi, I use this Tuya “switchbot” alternative connected via zigbee2mqtt . about 3 month of good working, but recently it go offline about 4 hours after repairing. I need to reset and repair to make it works . I changed a repeater too to boost coverage, but it seems to go sleep. Anyone have a similar behaviour?
Edit: the error reported by Z2M log is
Publish 'set' 'state' to '0xa4c138XXXXXXXX' failed: 'Error: ZCL command 0xa4c138XXXXXX/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 24012 - 1 - 57 - 6 - 11 after 10000ms)'
I try remove, disconnect USB coordinator, join by router, join next to coordinator… every time after about 4/8h it doesn’ t react to command but it seems alive (Z2M report last seen time to time)
