TS0011_switch_module
Zigbee Model: TS0011
Zigbee Manufacturer: _TZ3000_ji4araar
Description: 1 gang switch module - (without neutral)
It came with capacitor in the box. My question is - how to assemble it with light line where there is no N - line.
Where to connect this capacitor?
Thanks in advance.
Hello IoTer,
I assume it came with instructions, or else do a search for a diagram. The capicitor may or may not be needed, depending on the load, and it would go on the same 2 wires in the electrical box with the load.
Well that’s the problem, it did not come with instruction.
But thanks for your reply.
Well then the device has a line and a load, and I explained the cap.
Perhaps this would be good advice for you as well…
Disclaimer
:warning: DANGER OF ELECTROCUTION :warning:
If your device connects to mains electricity (AC power) there is danger of electrocution if not installed properly. If you don’t know how to install it, please call an electrician.
Beware: certain countries prohibit installation without a licensed electrician present
Remember: SAFETY FIRST. It is not worth the risk to yourself, your family and your home if you don’t know exactly what you are doing. Never tinker or try to flash a device using the serial programming interface while it is connected to MAINS ELECTRICITY (AC power).
