**Describe the bug**
A clear and concise description of what the bug is.
**T…o Reproduce**
Steps to reproduce the behaviour:
1. Pair the power strip via HomeAssistant ZHA
2. Once detected, locate the device in http://homeassistant.local:8123/config/devices/dashboard
3. Enter the device page and each of the switches are present
4. If you click one off, all will trigger off in 1-5 sequence a fraction of a second apart.
5. If you click one on, they all turn back on in the same 1-5 sequence.
**Expected behavior**
Each socket on the strip should be independently controllable separate to the others
**Screenshots**
<details>
<summary>Device signature</summary>
```yaml
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x010a",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0xe000",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"3": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"4": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"5": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"manufacturer": "_TZ3000_cfnprab5",
"model": "TS011F",
"class": "zigpy.device.Device"
</details>
<details>
<summary>Diagnostic information</summary>
```yaml
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.7.7",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/London",
"os_name": "Linux",
"os_version": "5.15.32-v8",
"supervisor": "2022.07.0",
"host_os": "Home Assistant OS 8.4",
"docker_version": "20.10.14",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"media_player_template": {
"version": "1.0.0",
"requirements": []
"hacs": {
"version": "1.26.2",
"requirements": [
"aiogithubapi>=22.2.4"
"govee": {
"version": "0.2.2",
"requirements": [
"govee-api-laggat==0.2.2",
"dacite==1.6.0"
"meross_lan": {
"version": "2.6.1",
"requirements": []
"miele": {
"version": "v2021.10.12",
"requirements": [
"requests_oauthlib>=1.3.0"
"watchman": {
"version": "0.5.1",
"requirements": [
"prettytable==3.0.0"
"midea_ac_lan": {
"version": "v0.2.2",
"requirements": []
"sonoff": {
"version": "3.1.0",
"requirements": [
"pycryptodome>=3.6.6"
"xiaomi_cloud_map_extractor": {
"version": "v2.2.0",
"requirements": [
"pillow",
"pybase64",
"python-miio",
"requests",
"pycryptodome"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.31.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.77",
"zigpy-deconz==0.18.0",
"zigpy==0.47.3",
"zigpy-xbee==0.15.0",
"zigpy-zigate==0.9.0",
"zigpy-znp==0.8.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 42297,
"model": "TS011F",
"name": "_TZ3000_cfnprab5 TS011F",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4417,
"power_source": "Mains",
"lqi": 255,
"rssi": -42,
"last_seen": "2022-08-03T14:26:55",
"available": true,
"device_type": "Router",
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0xe000",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"3": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"4": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"5": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006",
"0xe001"
"out_clusters": []
"242": {
"in_clusters": [],
"out_clusters": [
"0x0021"
"entities": [
"entity_id": "button.power_strip_1_d8b98fd1_identify",
"entity_id": "switch.power_strip_1_d8b98fd1_on_off",
"entity_id": "switch.power_strip_1_d8b98fd1_on_off_2",
"entity_id": "switch.power_strip_1_d8b98fd1_on_off_3",
"entity_id": "switch.power_strip_1_d8b98fd1_on_off_4",
"entity_id": "switch.power_strip_1_d8b98fd1_on_off_5",
"neighbors": [],
"endpoint_names": [
"name": "ON_OFF_PLUG_IN_UNIT"
"name": "unknown 97 device_type of 0xa1e0 profile id"
"user_given_name": "Power_Strip_1",
"device_reg_id": "227288f5a19d9e3568fb4db545308446",
"area_id": "bedroom",
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_PLUG_IN_UNIT",
"id": 266
"profile_id": 260,
"in_clusters": {
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"unsupported_attributes": {}
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x4001": {
"attribute_name": "on_time",
"value": 0
"0x4002": {
"attribute_name": "off_wait_time",
"value": 0
"0x4003": {
"attribute_name": "start_up_on_off"
"0xe000": {
"endpoint_attribute": null,
"attributes": {},
"0xe001": {
"attributes": {},
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZ3000_cfnprab5"
"0x0005": {
"attribute_name": "model",
"value": "TS011F"
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"2": {
"device_type": {
"id": 266
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"0x4003": {
"0xe001": {
"attributes": {},
"out_clusters": {}
"3": {
"device_type": {
"id": 266
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"0x4003": {
"0xe001": {
"attributes": {},
"out_clusters": {}
"4": {
"device_type": {
"id": 266
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"0x4003": {
"0xe001": {
"attributes": {},
"out_clusters": {}
"5": {
"device_type": {
"id": 266
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"0x4003": {
"0xe001": {
"attributes": {},
"out_clusters": {}
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
</details>
<details>
<summary>Additional logs</summary>
</details>
It is this device: https://zigbee.blakadder.com/Xenon_SM-SO306.html
