Thanks for posting this, it’s what finally worked for me!
I’m using a ZY-M100 (_TZE204_sxm7l9xa) and a HUSBZB-1 radio.
How do you exclude all the attributes? I see this thing calling home for signal quality multiple times every second. YIKES.
Instructions for the recorder are here - you want to exclude
https://www.home-assistant.io/integrations/recorder/
I excluded everything related to the sensor.
Is your device still working as expected? I just bought the same one, very disappointed. Slow to detect, gets stuck detecting.
Working, yes
As expected, nope - it’s cr**
Return it. Buy the athom.tech presence sensor.
Thanks, I will give up on this one… I’ve been looking for a 220v in-ceiling presence sensor. That device seems to be all over ali express, rarely using a recognizable device name across stores.
The unit I received also doesn’t match the picture, it only has one hole on the cover (for light sensor), the picture on aliexpress has 2 holes.
My quest continues.
Any experience with this one, it checks the right boxes:
ZigBee 24G MmWave Radar Human Body Presence Motion Sensor For Light Switch Luminosity Detection 110/220V Tuya Smart Life Home - AliExpress
I’ve tried a few and for me now it’s either the LinkNLink (which is cheap as chips and behaves as such, but works in some scenarios) or the Aqara FP2
Both sadly are Wifi but seem to work better than any of the zigbee ones i’ve tried
I’ve not tried the Everything Presence One, but also heard good things
I also have an FP2 in our living area, the zones have been working great for us.
This guy just came out with the video. He seems to like the ZY-M100, but I’m not sure his methodology included long term testing. He also ‘reviews’ the device I linked to above, but sadly doesn’t give any comments on its performance, more like an unboxing for that device.
(1513) Best mmWave Presence Sensors for Home Assistant! (WATCH before you BUY!) - YouTube
Super dumb question, where’s the code on this page? I am just seeing a conversation.
Nvm: found it. Doesn’t work with the SkyConnect ZB hub. The thing doesn’t initialize
Hi. Glad to hear. What is weird that for me this device, after pairing to Zigbee2mqtt, claims unsupported.
Probably I coul check the version of Zgbee2MQTT. Can the problem be in the version?
Installed version 1.35.0-1
Latest version 1.35.3-1
I will try and post the result here. - updated it did not help.
I added my human presence detector TS0601 like you describet and I added this ts0601_motion.py in folder.
But I have no new entities under my device (I also tryed to remove device an add it again).
Do I need do anything else?
Remember to restart Home Assistant after the change of the code, a reload of the component is not sufficient.
Yes, please show how you got it connected to HA!
Testing a 12v Zigbee ceiling mounted version of these Tuya Zigbee Human Presence Sensor 5.8g Or 24g Detect Human In And Out Motion Movement Detector - Buy Tuya Presence Sensor motion Detector zigbee Human Presence Sensor Product on Alibaba.com
I want a ceiling mounted sensor but building a new house and not interested with uncertified 220v items
Seems to get stuck on the state (away) even though it has detected my presence. Any ideas?
I have a couple of these Tuya ZigBee MmWave Human Presence Sensor 5.8G 24GHz Body Motion Detector 110/220V With 16A Relay For Lighting Smart Home System That I am trying to get working. But I havent had any success so far, probably doesnt help that I have no idea what I am doing.
Hi i bought 30 of this devices for my home, but when configure the 15 item all zigbee network died, this devices are very noisy, any idea about how reduce the data transmission of this devices?
I don’t know if it is possible, maybe you can use their Tuya app.
Try to have a router around ten of them, perhaps you are able to use them all together.
