I am using HA since may 2021 and have paired 22 devices (4 routeurs and 1 CC2531).
I just acquired the Tuya Smart Air House Keeper TS0601_smart_air_house_keeper.
And fortunately, I’ve seen that it was already supported by Zigbee2MQTT since the version 1.23.
I am using the just updated version 1.24.
But my problem is I can’t manage to make it pair. It is simply not recognized. The light blinks for about 5 minutes but at the end, it stops trying to pair.
Does anyone had this issue with this device or something similar ?
I tried to pair another unused device and it worked like a charm.
formaldehyde - statistics not working, unable to get graphical data, single entity okay.
pm2.5 entity - doesn’t show up for graphical data, not listed, but is available as a single entry.
If you take this device apart, you’ll find it has a cheap PM sensor (IR not laser) a temperature and humidity sensor and a VOC sensor. It apparently extrapolates estimated CO2 and formaldehyde based on the VOC sensor.
I is WAY off on CO2 compared to a real CO2 sensor. My current CO2 levels are 872 ppm real, and the Air Housekeeper says 357 ppm which is lower than it is outside. Worse, you can’t calibrate it, the incorrect reading does not correlate with the correct reading.
I’ve ended up labelling these inputs as fake CO2 and fake Formaldehyde on my install, and only using the real readings: Temperature, Humidity, PM 2.5 and VOC.
I had similar problems with the sensor itself - it showed inadequate values compared to the reference one. I took it apart and it turned out that there was a GP2Y10 PM2.5 dust sensor there.
