Flipper
September 7, 2023, 8:06pm
1
Hey there,
I’ve bought some smart radiator thermostat for my smart home setup and integrated them using the Home Assistant Zigbee stick, but it seems to be that they are not correct identified.
Maybe already my Home Assistant Stick is setup wrong, because until now I’ve just used my Hue Bridge. Since a few weeks I’ve also the Home Assistant Stick, because I thought it will ease up my setup somehow, but doesn’t seem so.
How I can access the smart thermostat using the Home Assistant Stick?
Flipper
September 10, 2023, 7:06pm
2
Solved using the qurik for ME167 - _TZE200_6rdj8dzm and customizing it as suggested in the following github issue.
opened 03:41PM - 21 Jan 23 UTC
integration: zha
### The problem
The problem is that the device is not recognized as a thermosta… t. Pairing went smoothly, but you don't see any entities for this device. It seems to me that it is a matter of adding another model to the system by the creators.
### What version of Home Assistant Core has the issue?
Home Assistant 2023.1.6
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Thernostat ME167
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/zha
### Diagnostics information
[zha-6ed2dcba0f670de7c970f75145d983b0-_TZE200_6rdj8dzm TS0601-3ff4062b42de1a0246b48f046d8bbf22.json.txt](https://github.com/home-assistant/core/files/10472455/zha-6ed2dcba0f670de7c970f75145d983b0-_TZE200_6rdj8dzm.TS0601-3ff4062b42de1a0246b48f046d8bbf22.json.txt)
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
Using this quirk for the mentioned device
