TS0601_TZE204_bkkmqmyo
Hello!
Hello!
Does anyone use this version of the energy meter?
https://www.aliexpress.com/item/1005002409593441.html?spm=a2g0o.order_list.order_list_main.45.32731802Vak3LA
Joins ZHA but does not see any entities. I read a lot of topics about the clamp meter version, but I can’t get anywhere.
Just got the same device as I thought it would work with Z2M, but same behavior as for you with ZHA. Device is just detected as not supported…
I hope this tool gets support as soon as possible. The device has very favorable functions, which is why I chose it.
I have added support, just wait for the next release which contains the herdsman converter or create an external converter in the meantime if you are impatient :grinning:
See [Detect]: _TZE204_bkkmqmyo as HIKING DDS238-2 · Issue #20138 · Koenkk/zigbee2mqtt · GitHub for details.
I would also be interested if you experience the same delays of reported values
Thanks! Sorry, I’m a bit late to answer. I’m glad you were able to add support. I couldn’t try the converter because I use ZHA. I’ll wait, the support will still be included. Thanks for addressing the issue!
Any news here?
This is in lay terms the “2023 edition” of the “real” Hiking DDS238-2 and the supply of the 2021 version which has a bit better support is close to 0 now (TOMZN themselves seem to have some hidden in the cellar which you might get if you give them a good reason).
None of the several TS0601 quirk files you can find on the net get everything right. Most are using fixed divisors/multipliers instead of getting the values off the device.
Hi:
I bought 3 Hiking DDS238.2 from Ali Express on September last year. I could integrate them to my HOme Assitant using MQTT. I got 4 new POwer Meter, same model, same vendor and I just could not intregrate my new Power Meters. Checking my logs:
warn 2024-07-29 16:48:16: Received message from unsupported device with Zigbee model ‘TS0601’ and manufacturer name ‘_TZE204_bkkmqmyo’
warn 2024-07-29 16:48:16: Please see: Support new devices | Zigbee2MQTT
warn 2024-07-29 16:48:17: Received message from unsupported device with Zigbee model ‘TS0601’ and manufacturer name ‘_TZE204_bkkmqmyo’
As I have a docker installation,I pulled latest docker images and could solve the problem, now I can see my 4 new devices.
REPOSITORY TAG IMAGE ID CREATED SIZE
Package home-assistant · GitHub stable a69fbd0b10a5 14 hours ago 1.58GB
koenkk/zigbee2mqtt latest ebc572280a69 4 weeks ago 119MB
eclipse-mosquitto 865fd43c0ce6 10 months ago 14.5MB
user@Ra:/opt $ date
Tue 30 Jul 18:23:48 -05 2024
