OK so to Sum up, I installed Motioneye on HA and was quickly able to get a Amcrest Camera working. I then went to get a TTGO Cam working and it only will work for a short while and then I must re-setup the cam.
My configuration for the TTGO cam is through ESPHOME
substitutions:
devicename: ttgocam1
friendly_name: Steve-Cam
ip_address: 192.168.1.100
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: dlink4
password: "1234567890"
manual_ip:
static_ip: 192.168.1.101
gateway: 192.168.1.1
subnet: 255.255.255.0
fast_connect: on
` # Enable fallback hotspot (captive portal) in case wifi connection fails
`# ap:
`# ssid: "Ttgocam1 Fallback Hotspot"
`# password: "1234123412"
`# ap_timeout:
`# seconds: 30
`# Enable logging
logger:
`# Enable Home Assistant API
api:
ota:
binary_sensor:
- platform: gpio
pin: GPIO33
device_class: motion
- platform: gpio
pin:
number: GPIO34
mode: INPUT_PULLUP
inverted: True
- platform: status
- platform: wifi_signal
name: $friendly_name WiFi Signal
update_interval: 10s
- platform: uptime
`# - platform: homeassistant
`# entity_id: sensor.weathermet_temperature
`# id: out_temp
mqtt:
broker: 192.168.1.207
username: MQTT
password: password
`text_sensor:
` - platform: mqtt_subscribe
topic: weather/temp
`#display:
`# - platform: ...
`# lambda: |-
`# it.printf(0, 0, id(font), "The Temp is: %s", weather.home.state.c_str());
esp32_camera:
external_clock:
pin: GPIO32
frequency: 20MHz
i2c_pins:
sda: GPIO13
scl: GPIO12
data_pins: [GPIO5, GPIO14, GPIO4, GPIO15, GPIO18, GPIO23, GPIO36, GPIO39]
vsync_pin: GPIO27
href_pin: GPIO25
pixel_clock_pin: GPIO19
power_down_pin: GPIO26
resolution: 640x480
jpeg_quality: 10
vertical_flip: true
horizontal_mirror: true
i2c:
sda: GPIO21
scl: GPIO22
font:
- file: "fonts/times-new-roman.ttf"
time:
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%s", id(weather.home.now());
# it.strftime(64, 0, id(tnr1), TextAlign::TOP_CENTER,"%d-%m-%Y", id(homeassistant_time).now());
# it.strftime(64, 64, id(tnr1), TextAlign::BASELINE_CENTER, "%d-%m-%Y", id(homeassistant_time).now());
# it.strftime(64, 128, id(tnr1), TextAlign::BASELINE_CENTER, "%A", id(homeassistant_time).now();`
Motioneye config
url I used for the cam Web url
http://Something.Something.com:8123/api/camera_proxy_stream/camera.steve_cam_camera?token=dbc6b69b8784224847cfad2240021601ba220b7b15966adc58c2702924d0cf0b`
Do I need to edit my configuration.yaml file? If so please let me know, I created a token to never expire and tried just appending it to the url after the “token=” part of the url but that failed. Any assistance would be appreciated.
