TTS announcement on Sonos
Good day everyone.
I’m brand new to home assistant, but fairly technically minded. Having fun so far!
I’m trying to get a TTS service running on my Sonos.
  • I have two sonos connected. Both Sonos One. Both running S2 firmware.
  • They were automatically detected by HA:
    entity_id: media_player.kitchen
    entity_id: media_player.dining_room
  • I can play/pause/change tracks from the HA dashboard
First I tried this one, which I found in the forums:
service: media_player.play_media
  media_content_id: media-source://tts/google_translate?message="I am very loud"
  media_content_type: music
  announce: true
  extra:
    volume: 80
When I run the “Then do”, I get this error: Provider google_translate not found
Second, I tried to build the automation from scratch in the UI, which resulted in:
  media_content_id: >-
    media-source://tts/tts.google_en_com?message=Hello+Homey%2C+you+can+play+any+text+on+any+supported+media+player%21&language=en-ca
  media_content_type: provider
metadata:
  title: Hello Homey, you can play any text on any supported media player!
  thumbnail: https://brands.home-assistant.io/_/tts/logo.png
  media_class: app
  children_media_class: null
  navigateIds:
    - media_content_type: app
    - media_content_type: provider
This one says “Action successfully run”, but nothing comes out of the Sonos.
Could someone please help me in getting a TTS working over Sonos?
Thanks in advance!
why not this?
service: tts.speak
  entity_id: tts.google_en_com
  media_player_entity_id: media_player.sonos
  message: hello world
you have to make sure you have the google tts integration added of course:
Thanks for the quick reply.
I tried as you suggested, but no luck (nothing comes out of the speaker).
And yes, the google tts integration is already added.
Just wrapping this up in case it helps anyone!
It all came down to either the external URL or the SSL cert (or lack thereof).
I tried for hours and hours all kinds of different TTS scripts and none would ever play over the Sonos (even though I could control music on the Sonos through HA with no problems).
In the end, just enabled Home Assistant Cloud, and it worked. So I feel like it has something to do with unsigned calls from HA to Sonos…
Anyway, glad it works now.
glad you got it to work.
do you have your home assistant on ssl?
the way that tts.speak works is that it creates the audio file then exposes it with the local url of your home assistant and points sonos to it. so unlike media controls, where the commands are sent to sonos, in this case, sonos needs to be able to http back to home assistant. if you have home assistant ssl’ed or somehow separated in different networks, then sonos would need to be able to get the correct (usually external ssl link)…
if you have them all on the same subnet and no ssl… which is the config i run, then i dunno… but regardless, glad it’s working
Instead of starting a new topic, I will try to hop on this train, as I’m having the same conditions.
I had set up some TTS alarms with my Sonos and a Nest Hub 2, and they used to work. Then, I connected my HA server (HAOS) to the outside world using DuckDNS. A while later, I discovered that I cannot use TTS anymore.
The rest of the automation does work, it’s just the TTS which doesn’t.
I use the GUI, and do:
Media player → Play media → Select the speaker, then Pick Media → TTS
I tried with both Home Assistant Cloud (even though I have not connected that, just to see what happens) and Google Translate. These are the two TTS options I have. I select the correct language (Canadian French), enter the text, save, and… nothing…
Here’s the code for that action (created from the GUI). Any help will be welcome.
action: media_player.play_media
  entity_id: media_player.salon
    media-source://tts/tts.google_translate_en_com?message=Le+cong%C3%A9lateur+du+frigo+est+ouvert&language=fr-ca
metadata:
  title: Le congélateur du frigo est ouvert
  media_class: app
  navigateIds:
Hey sorry just seeing this now, did you get it working?
Same problem here, can’t send any tts message to sonos (or google nest), no cloud service. Anybody who solved this without the cloud?
I have the same issue. Sonos will pause playing when I try and send a TTS message to it.
If I try the TTS action with the Sonos app open, the app will display a message: “Unable to play [long string of numbers].mp3 - The connection to [my HA server].com:8123 was lost”. If I hit Play in the app, the same message appears, so clearly the message was added to the queue.
BTW I do have a valid (LetsEncrypt) certificate on my HA server.
I had the same problem, found out that it was the url settings in the settings → system → network that was not configured correctly.
After correcting this the url for the mp3 link sent to the sonos speaker was correct and the TTS action worked.
