Hi all,
While playing with the Voice Preview device, I noticed that HA writes caches files in the ~/config/tts/* directory.
In my case this is directly writing to the SD card on my Raspberry.
I expect the config dir to be fairly static and not having much reads/wites.
For all Docker things, a separate USB SSD drive is attached where docker reads/writes images/containers/layers etc.
In the past we could configure a separate yaml file with cache options for HA/tts.
Nowadays this is controlled under the surface.
I want to preserve my SD, and set the cache directory to somepath either Ramdisk, or docker path( eg /dev/shm/ within the container). Can we do this?
Best regards!
