Tts.cloud_say FileNotFoundError since 2022.5
Since upgrading to 2022.5 my tts automations have been failing, in the logs I get:
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/apple_tv/media_player.py:292
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 22:24:05 (1 occurrences)
Last logged: 22:24:05
[140387879281760] Error handling message: Unknown error (unknown_error)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 626, in handle_execute_script
    await script_obj.async_run(msg.get("variables"), context=context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1513, in async_run
    await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 405, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 449, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 472, in _handle_exception
    raise exception
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 447, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 680, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1627, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1664, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 217, in async_say_handle
    await hass.services.async_call(
    task.result()
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 677, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 714, in _handle_entity_call
    await result
  File "/config/custom_components/apple_tv/media_player.py", line 292, in async_play_media
    await self.atv.stream.stream_file(media_id)
  File "/usr/local/lib/python3.9/site-packages/pyatv/core/facade.py", line 382, in stream_file
    await self.relay("stream_file")(file, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/pyatv/protocols/raop/__init__.py", line 371, in stream_file
    audio_file = await open_source(
  File "/usr/local/lib/python3.9/site-packages/pyatv/protocols/raop/audio_source.py", line 484, in open_source
    return await FileSource.open(source, sample_rate, channels, sample_size)
  File "/usr/local/lib/python3.9/site-packages/pyatv/protocols/raop/audio_source.py", line 428, in open
    src = await loop.run_in_executor(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.9/site-packages/miniaudio.py", line 929, in decode_file
    filenamebytes = _get_filename_bytes(filename)
  File "/usr/local/lib/python3.9/site-packages/miniaudio.py", line 807, in _get_filename_bytes
    raise FileNotFoundError(filename)
FileNotFoundError: media-source://tts/cloud?message=Hello+I+am+testing+this
I tried adding media_source: to my configuration.yaml file but even after a restart I get this same error. I also tried setting the local network URL to automatic but still the same.
Any ideas?
Thanks!
Issue was caused by having the Apple TV Beta Component installed, removed and working fine now.
