Any script or automation using tts.cloud_say isn’t working anymore since I upgraded to 2022.5.0 and raises an error in home-assistant.log:
2022-05-05 17:31:39 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140402381049040] Media Source not loaded
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 189, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1627, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1664, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 217, in async_say_handle
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 677, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 714, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 608, in async_play_media
sourced_media = await media_source.async_resolve_media(self.hass, media_id)
File "/usr/src/homeassistant/homeassistant/components/media_source/__init__.py", line 130, in async_resolve_media
raise Unresolvable("Media Source not loaded")
homeassistant.components.media_source.error.Unresolvable: Media Source not loaded
Even using the tts test from the Home Assistant Cloud configuration raises the same error:
Anyone having the same problem?
