TTS , Google home, HTTPS and loopback. Help!
My router does not allow loopback so i can’t access Https://MYHASS.duckdns.org setup from my internal network. I can only access it via Https://192.168.1.100:443 which is fine for most things (despite browser moaning).
If I use TTS the file is created. I can access it internally but Google home will not play the file, for example, https://192.168.1.100:8123/api/tts_proxy/aaf4c61ddcc5e8a2dabede0f3b482cd9aea9434d_en_-_google.mp3 . I am assuming this is because there is a certificate mismatch.
Is there anyway of turning off https for internal access only? Or saving the file elsewhere?
Any ideas or help would be helpful.
Wayne
I think this is the same issue I have. Did you ever figure it out @Wayne_Williamson?
Figured it out - I was able to enable NAT loopback on my router
What can I do if my router does not support NAT Loopback and locked DNS settings? is there any work around so that Google Home can Text to Speak?
Hey, I figured it out it was the syntax of the base url when I dropped the https:// everything start to work!
base_url: mydomain.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Anyone figured how to to this with a router without NAS loopback capability?
Have you managed it?
My config:
No NAT loopback/hairpin available & DNS locked on router from IPS
Symptoms:
  • TTS not working
  • HA not working from local network via SSL link
Preferred solution:
Keep IPS’s router (without investing to the new one with NAT capability together with IPS’s router in bridge mode)
