Tts.google_say no longer works as of last few days
I have not updated HA lately (I am on 2026.3.4) but in the last 2-3 days my announcements to speakers around my house have stopped working. Or almost stopped working – I get the usual tone when they should then speak, but no words.
action: tts.google_say
  message: This is a test message
  entity_id: media_player.master_bedroom_speakers
I use nabu casa for google integration, and this has worked for many years. I wondered if it was node red since that’s where it usually originates, which is why I just tried the above in the developer console and – tone, no words.
I of course have no idea if the speakers were updated; I neither control nor see that, google does.
It’s a consistent, persistent problem, not intermittent.
Anyone else having this issue, or have any ideas?
To my knowledge nothing else is failing. I can cast (e.g. from my phone) to these speakers without issue. And as mentioned – when I do the above statement (at least the first time) I get the “Message coming” type tone to show they are on and it did connect.
Linwood
PS. “Hey Google” results in hearing the response just fine, at least 80% of the time (it’s always been a little iffy whether the whole response comes out, that’s not new.
This ends up being a “never mind”.
I had changed the internal address of the ha server to a specific IP, and had a typo in it. The external was correct (and resolves to the inner IP as I never use it from outside other than over a VPN).
What’s really odd is that the incorrect IP actually seemed to work for everything but this, at least nothing else failed.
Weird.
Fixed it, and now the tts-say works.
Hi, good you it got solved yourself!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
