Hi all,
I’m just playing around with what I could do with google automation… I tried to set up a weekday event for Google to speak aloud at me in the morning… But it’s not working out.
The Automation:
- id: '1599993657128'
alias: Wake up for work
description: ''
- at: 06:50:00
platform: time
condition:
- after: 06:50:00
condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- data: {}
entity_id: switch.sonoff_bedroom_light
service: switch.turn_on
- data:
message: 'Wake Up!'
service: tts.google_translate_say
entity_id: media_player.house_speaker
mode: single
I can see the bedroom light comes on fine but I then at the google_translate step it fails with 2 errors in the log:
Log Details (ERROR)
Logger: homeassistant.components.automation.wake_up_for_work
Source: helpers/script.py:906
Integration: Automation (documentation, issues)
First occurred: 6:50:00 (8 occurrences)
Last logged: 13:39:03
- Wake up for work: Error executing script. Invalid data for call_service at pos 1: required key not provided @ data[‘entity_id’]
- Wake up for work: Error executing script. Invalid data for call_service at pos 2: string value is None for dictionary value @ data[‘message’]
- Wake up for work: Error executing script. Invalid data for call_service at pos 2: required key not provided @ data[‘entity_id’]
Source: core.py:1262
First occurred: 6:50:00 (7 occurrences)
Last logged: 13:35:34While executing automation automation.wake_up_for_work
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 430, in async_trigger await self.action_script.async_run(variables, trigger_context) File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 802, in async_run await asyncio.shield(run.async_run()) File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 183, in async_run await self._async_step(log_exceptions=False) File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 191, in _async_step await getattr( File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 380, in _async_call_service_step await service_task File “/usr/src/homeassistant/homeassistant/core.py”, line 1262, in async_call processed_data = handler.schema(service_data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled(, data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: required key not provided @ data[‘entity_id’]
Any ideas what’s going on?
