Hi
You know the UI when you pick a media player where you can write text to be announced in the speaker!
It just changed from swedish to english, without any configuration changes. I dont belive i’ve seen any breaking change either?
In the UI it also says en-US, cant say I’ve seen that before.
What can I do to return its default translation to Swedish?
Same problem tried all the suggestions I could find, but nothing seems to work the strange thing is it worked for a couple of weeks without any issues and was used a lot here!
OK stupid me after reading the manual, github issues a little better this works for me with the Mini Media Player card (https://github.com/kalkih/mini-media-player) always thought it was using the global config but it seems you can change this directly for the card itself and that works for me!
I could not find yet a solution for the default media card, but because I only use the more superior custom custom Mini Media Player card (highly recommended) this fixes it for me!
I also created a simple thing to send message with different TTS services (Reverso, Nabu Casa) this way I can use different languages son loves that and learns from it
