TTS + LG WebOS TV (TTS message not working on TV)
I have LG WebOS TV which can be controlled in HASSIO automations. I have a PIR sensor(at door) which changes source from HDMI-3(connected to Set-top box) to HDMI-2(connected to CCTV camera outside door) when motion is detected and back to HDMI-3 when motion stops.
In short : When motion is detected, I see the CCTV output on TV for that duration.
So I wanted to use TTS so that I can hear a message from the TV.
In logs, I see as below : **
Error executing service ServiceCall media_player.play_media: media_content_id=http://192.168.1.110:8123/api/tts_proxy/669fb92c17b8930dbb84f4c07c1b6a7119313ee8_en_-_google.mp3, media_content_type=music
** File “/usr/lib/python3.6/site-packages/homeassistant/core.py”, line 1002, in _event_to_service_call
** await service_handler.func(service_call)**
** File “/usr/lib/python3.6/site-packages/homeassistant/components/media_player/init.py”, line 402, in async_service_handler**
** yield from getattr(player, method[‘method’])(params)
** File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run**
** result = self.fn(self.args, self.kwargs)
** File “/usr/lib/python3.6/site-packages/homeassistant/components/media_player/init.py”, line 693, in play_media
** raise NotImplementedError()**
NotImplementedError
If I put this link “http://192.168.1.110:8123/api/tts_proxy/669fb92c17b8930dbb84f4c07c1b6a7119313ee8_en_-_google.mp3” in a browser on PC, the mp3 file which gets created for the voice message runs correctly but on the TV i hear nothing.
Can someone help ?
did you find a solution ?
Having same issue here. LG webos. Haven’t been able to figure out a solution yet.
When I do a TTS message, it saves it as mp3 file inside the config/tts folder. When I play these mp3 files on my computer, the text message is actually correct.
Hopefully one more bump can help raise awareness or maybe someone has been able to figure it out.
Did anyone have been able to work out the TTS on webs tv?
Mark
Not yet :frowning:
Is this still not solved? :frowning:
I’m having the same issue.
Same here.
I want to use my web OS TV as output for the Assistant + ChatGPT.
But it won’t work.
