I was trying to use the Microsoft TTS but get errors.
I Got this when using Hass Config Check.
2017-11-08 18:56:15 ERROR (MainThread) [homeassistant.config] Invalid config for [tts.microsoft]: value is not allowed for dictionary value @ data['gender']. Got 'female' value is not allowed for dictionary value @ data['language']. Got 'en-gb'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/tts.microsoft/ 2017-11-08 18:56:16 INFO (MainThread) [homeassistant.setup] Setup of domain ios took 0.0 seconds. Failed config tts.microsoft: platform: microsoft api_key: retracted cache: True cache_dir: tts gender: female language: en-gb time_memory: 300 type: Susan Successful config (partial) tts.microsoft:
Had a look in /home/hass/.local/lib/python3.5/site-packages/homeassistant/components/tts
and it the microsoft.py was not there…
Any Help
