TTS not working after update
Starting with 2022.7 tts notifications sent via HACS Alexa media player have stopped working. Setting the type to announce does work but tts does not. I’ve uninstalled the integration and removed it from HACS and reinstalled both. I have also updated to 2022.7.7
This does not work:
service: notify.alexa_media_office_echo
  message: This is a test
    type: tts
This does work:
    type: announce
I’m not seeing any errors in the logs.
Not sure if you’ve found a solution by now - I had to change my actions from
service: notify.mobile_app_dashboard
data_template:
  title: "{{ trigger.to_state.name }} now {{ trigger.to_state.state }}"
  message: TTS
    ttl: 0
    priority: high
    channel: alarm_stream
to this
  message: TTS
    tts_text: "{{ trigger.to_state.name }} now {{ trigger.to_state.state }}"
    media_stream: alarm_stream
    priority: high
Note that there is no need for using ‘data_template’ any more, it works fine with the ‘data’ definition.
