Had this topic half a year ago. So wonder if there was any improvement.
Is there any component to pass TTS and sounds to a remote linux machine except for kodi?
It must be a separate entity (not play all the sounds HA does)
No bluetooth can be involved (remote machine is using it to play the sounds)
For this to work currently - running 2 HA isntances with MQTT automations. But would love to remove that
Maybe use the shell command component to ssh into the machine?
It’s an option. There even was a script here that allowed to push cached mp3 via ssh to remote machine.
But what about MPD or cmus - can they do it now being on a remote machine?
MQTT and 2 HA instances are working fine. However when using somthing like
- service: tts
entity_id: media_player
data_template:
message: ’ {{ [ “message1”, “message2”, “message3” ] | random }}
I will get different say outs. Wonder if this string of text can be generated and then i could send it out via let’s say MQTT topic and also pass to tts service so they will be synchronised
