man coding is different here
media_player:
- platform: bluetooth_speaker
address: 88:C6:26:AC:41:1F
volume: 50
media_player:
volume: 50
Ahhhā¦ can you change the address to use underscore instead of colons?
And volume needs to be between 0 and 1.
So replace your config with this:
media_player:
address: 88_C6_26_AC_41_1F
volume: 0.50
I will modify the code to support colons, but for now, just underscores supported.
I ment pasting code in forums is different then in the chat
I changed the colons out still same issue. I am going to try with different speaker in the am. Thanks for help so far
If Iām using the same bluetooth adapter for presence detection via detecting my miband or my mobile phone (I have to look into how I did this), will I be able to use the same adapter for this purpose too? Or are these adapters single purpose, if they are constantly listening for a bluetooth device they cant be transmitting?
@marksev1 I think youāre right here. As soon as I enabled Bluetooth presence detection tracking in HA, the TTS playback became choppy on the Bluetooth speaker.
I wonder if there is a way to temporarily stop the Bluetooth adapter from listening so that the TTS can be played, and then resume the listening?
Just for testing, I set the Bluetooth scanning interval to 5 minutes (300 seconds), and after doing that, the TTS playback was smooth, without any choppiness.
- platform: bluetooth_tracker
interval_seconds: 300
Looking at the HA Bluetooth presence tracker code, I can see that the scanning is done with a duration of 8 seconds and the default interval is 12 seconds. I guess that means there is only a 4 second window of idle time between cycles.
Anyway, something to look into furtherā¦
Iāve created a GitHub repo for this custom component.
The new version of the component no longer includes the associated shell script (play_url_bluetooth.sh
) since the component itself (i.e. Python code) does the work the script used to perforn (i.e. launches mplayer with the correct parameters).
So, all you need to do is copy the new version of the custom component from the GitHub repo:
custom_components/media_player/bluetooth_speaker.py
Iāve also included a sample media player config:
media_player.yaml
address: 00:2F:AD:12:0D:42
volume: 0.65
# cache_dir: /tmp/tts # Optional - make sure it matches the same setting in TTS config
As you can see, the Bluetooth deviceās address
now supports colons rather than only underscores. Also, the cache_dir
setting should be set to the same directory as what you have in your TTS config (if youāve specified it all). This is because the new version of the component no longer saves a copy of the MP3 file from the TTS URL, but instead, it plays the original MP3 file from the TTS cache folder.
I havenāt tried it myself, but you should be able to. See https://www.youtube.com/watch?v=mhtvWn70meA
I managed to make it work, but i have to connect the portable speaker manually with ābluetoothctl
ā and then āconnect FC:58:FA:D2:84:0
ā
Iām guessing this is because of my cheap speaker (this one: Myria DC-0598)
I will try again tomorrow evening when I return from work with a pair of Soundsticks III
I think my real problem was with some permisions, i donāt run homeassistant from pi user, i have a separate user āhomeassistantā for it, and I created the files in guest mode from samba using a mac. I figured it out after testing the
mplayer -ao pulse::bluez_sink.88_C6_26_AC_41_1F -volume 50 /tmp/crowd.mp3
command and received an acces denied.
@hackertc Great to see progress!
Did you add your homeassistant
user to the pulse-access
group? Maybe that will help with permissionsā¦
sudo adduser homeassistant pulse-access
yes, i did this and fixed my problem (forgot to mention in the last post) I will play with it and come back with some feedback and suggestions if i can find any
@hackertc Are you using the latest version of the bluetooth speaker component I put on GitHub, or the original one from the first post?
Made some good progress on this. I am close to releasing the latest version. This one allows the following two components to play nicely together:
As was discussed already, since the Bluetooth tracker constantly scans for devices, it interferes with the playback of audio on the Bluetooth speaker. After trying lots of approaches, the only one that worked was to power off, and power on, the Bluetooth on the Raspberry Pi. That terminates any existing presence detection scanning, granting the Bluetooth speaker exclusive access to the Piās Bluetooth. Once the MP3 file has completed playing, access to Bluetooth is handed back to the Bluetooth tracker.
The flow is something like this:
A bit more testing to do, but in the next day or so, I will put it up on GitHub.
Iāve been testing for a while now, playing lengthy TTS files, and each one is played seamlessly (without any interruptions). Between these TTS playbacks, I can see the Bluetooth tracker scanning and finding devices. So both of these scenarios seem to be coexisting just fine.
OK, itās now ready on GitHub. Only three files are required to make this all work:
custom_components/device_tracker/bluetooth_tracker.py
custom_components/media_player/tts_bluetooth_speaker.py
configuration.yaml
device_tracker:
media_player:
- platform: tts_bluetooth_speaker
volume: 0.45
I tested it using Developer Tools > Services int he HA frontend:
This works well on my system, so let me know how you go.
UPDATE: Another improvement. In the Bluetooth tracker, there is no longer any need for the code to power off, and power on, the Bluetooth on the Raspberry Pi, in order to cancel any pending scans (i.e. inquiries). Instead, it now calls a low-level Bluetooth library to cancel the āpending inquiriesā. Much nicer than power cycling the Bluetooth!
Does this work with the Bluetooth low energy tracker enabled?
I should give the onboard BT a chance instead of taking dongle maybe
@thundergreen I have only been using the Raspberry Pi onboard Bluetooth module. Would be interesting to see if this works the same using a dongle.
Doco has been added to the GitHub repo, and I have updated the first post in this thread to rermove the āoldā instructions, and point everyone to the GitHub repo instead.
